In double-checking my Bilstiens after the latest info, I noticed that per the FFR Shock Inspection Procedure the numbers should be 273 T0 for fronts and 274 T0 for rears (solid axle). Mine have the correct 273 and 274 respectively but the suffix for both is T1 so they are 273 T1 and 274 T1.
Does anyone know offhand what the T0/1 suffix represents?
Nope, but you should call Factory Five to have them make the decision on whether or not you can run what you have.
I have the same situation and called FFR. They said the T1 is the same shock, just a little later manufacture. They said no problemo.
Thanks guys. Everything else checks out so it looks like I'm outta the woods with the shock issues.
