1 - 3 of 3 Posts
I have a bare block 351W that I am building for a Cobra and I would like to go to Serpentine belts.
I've seen a bunch of them on different forums' classified, but most of them are for 302's. Will the 302 pulleys fit the 351W balancer, waterpump, alternator, and power steering pump?- Bob
The pulleys will fit back and forth between a 351 & 302. It's the brackets that are different. You will want to use Mustang brackets or ones from March. I sell brackets that fit non-power std rotation.
Mike Forte
Yes they will, but you will most likely need a spacer for the crank shaft. Mike Forte sells them, they are a Ford Racing part. He knew which one I needed. Other than that just use a 302 water pump and brackets for the other stuff.
Nathan
1 - 3 of 3 Posts
