Hi all,
I need to install seat belts (Simpsons furnished with kit) in FFR5106. Any one have photos of the finshed installation(s)?
Thanks!
Chuck
"Mustang Medic"
FFR5106
What - exactly - do you need a photo of?
Here's a little trick. If you bolt the supplied seat belt tab to the welded on brackets, the top of the bracket compresses the seat belt webbing. Eventually, this will wear a hole in the webbing. And it will be impossible to adjust the belt. Place a couple of washers between the bracket and the tab.
Russ and boB,
Thanks for the info-I will add the washers on the rear tab in the trunk. I mocked up the driver's side last night and got the basics sorted out. I had to run a 1/2 inch drill through the bracket holes to clear out the powder coat. The rest of the fitting went well.
Thanks!
Chuck
Don't forget to add the washers to the lap belt brackets as well.
