I decided to do some preventative maintenance and swap out my 15 year old Holley fuel pump with a new Edelbrock Victor Jr. 130 GPH mechanical pump. The old pump was down to 4.5 pounds of pressure and while still OK I did not want to end up getting stranded someplace with no fuel pressure.
To get access from the top I pulled the PS pump, loosened the pump mounting bolts a couple of turns and rotated the motor until I could feel the eccentric come off the pump lever and then removed the pump. In doing the mock-up I found it very difficult to hold the pump in place and start the bolts at the same time so cut the head off of a 3/8" x 1.5" bolt and slotted it with my Dremel. I then used this as a pin to help hold the pump while I started the other bolt without fear of cross-threading the timing cover. Worked like a charm. Once the first bolt was tight it was easy to remove the "pin" with a screwdriver and install the second bolt. Used a little Form a Gasket #2 and tighten to 20ft/lb. Easy-peasy. Scott
