1 - 1 of 1 Posts
This is on a new build, Mk 3.1, SN95 spindle. Just wanted to get clarification; the UCAM torque spec for the bracket bolts (1/2 inch) calls for 50 ft-lbs for all 4. Per the directions. Even though the original UCA mount called for 100-110 ft-lbs.
The upper bolt holding the brake caliper on is virtually impossible to get to with the new IFS and coil-over spring in place. Already checked that correct IFS is on correct side. To torque this or for brake pad replacement, for that matter, it seems like you have to take apart the spring and IFS (5/8") bolts. If this is correct, fine. Just wanted to check before proceeding. Good thing I'm using blue treadloc. Thanks for the help. Happy Holidays. Marlin
1 - 1 of 1 Posts
