I did a search but I couldn't find anything specifically about what I'm looking for. I mounted my RT turn signal column to my steering shaft and it looks like it puts the wheel too close to the dash. I know that you can pull the shaft out a little to move the wheel back but if the RT turn signal column is bolted to the frame you wind up with a big gap between the column and the hub. I was thinking about making a spacer to space the column off of the frame but I thought I'd see if anyone else had the same problem first.
Tom
Thanks Russ,
I'll be mocking up the dash panel next weekend so if it feels like I'm going to be rubbing knuckles on gages I'll let you know. Honestly, it's difficult to tell with my dash cut in half.
BTW, the column is beautiful! It really improves look of the interior.
Tom
