I see Mike Forte has the rubber set on sale. Just wondering which type most are using and any issues with either.
I used rubber and regretted it. Going poly this time.
When you run hard, the engine block moves so much my pipes touched the bodywork!!
I had the same problem as 2savage, pipes hit the body. Get the poly ones. The rubber trans mount is fine.
David W
Non-whiner
The polys are stiff enough that the engine doesn't move too much, yet, pliant enough that you don't feel every vibration. Another vote for poly.
Discussion Starter #6
Good info. I forgot the side pipe movement would be an issue. Thanks.
I wore out a set of the convertible mounts and changed over to the poly ones. No difference in the vibration level. I did have to enlarge the sidepipe opening a little.
