I have a ford 302 crate engine and I am concerned about the clearance between the top of my rocker arms and my new valve covers.
If I remove the oil drip tabs from the inside of the covers there is plenty of room.
Is that ok?
Jon
Official OLD GUY
Oil deflectors
You might just want to "dent" the deflector tabs a bit. Others have complained about the rocker just underneath it, throwing oil out the fill tube if the baffle is completely removed.
Doc :beerchug:
get a can of Play-Doh and roll up a small ball. Put it on top of the rocker, then set the cover in place without a gasket. Push the cover down and then remove. Check the impression in the Play-Doh.
Dwight
2010 FFCars Graduate
Don't know which valve covers you are switching to, but another forum member did a nice write up with pics on how to modify a set of the finned cobra valve covers to work. I followed his process and it worked on mine.
Forum name dv/dt. I had a link saved but it no longer works. You might try to pm him.
Here's the write-up I did a while back on my mod to use the FRPP F302 "Cobra" valve covers:
I used the F302 covers on my 302 with a small mod. My config is Edlebrock Performer RPM heads with Comp Cams Pro Magnum roller rockers. I am also using the Felpro thick gasket (1645). I started by placing play dough on the adjusting nuts to check for clearance. The covers were then installed and torqued down (4 lb-ft - spec is 3 to 5 lb-ft). As you can see there was some slight contact as the dough was squeezed out on part of the nut (sorry this pic is fuzzy):
Here is the baffle before reshaping:
I remove the baffle and reshaped as shown here:
There are three stand offs under the baffle.
I trimed the two outboard ones (the right ones in the pic) to allow the baffle to fit properly:
The baffle was reinstalled and the play dough was rechecked with the following results.
Lot's of clearance.
Cheers, Rod
Cheers, Rod
Yes, Those are my valve covers. Very clever method.
I will try it this week.
This forum seems to have an answer for everything!
-Jon
