Looking for the best ride height. Did a search and came up with some different numbers. It has power steering. Using the following for set up:
Castor 6-7 degrees
Camber - 0.5 degrees
Toe - 1/16 total toe in.
front ride height 4.5" ????
Rear ride height 5.5" ????
Chuck
IMHO those numbers are about 1/2" too high. Obviously it does depend on the type of roads you usually drive on though.
As per post in the other forum:
4" level front & rear with nothing hanging below the main chassis tubes. No contact with speed bumps when driven over them slowly.
At 3.75" would scrape on the taller ones.
I?m personally 4.5 in front and 4.75 in rear with nobody in the seats. Your mileage may vary
4" in front, 4.5" in rear.
