Got my first GTM a few weeks ago.... crazy hard to get it into reverse.... any suggestions
Pro FFR Builder and Moderator
Make sure the clutch s fully depressed. There is a hump in the floor that can keep your foot from going all the way down. Reverse seems to need a little more clutch than the forward gears
This is normal for G50 transaxles. We've built/worked on over 30 GTM's here and all of them with a G50 is difficult to get into reverse. There is a stiff detent to get past.
When shifting to reverse, try taking your right palm and "slapping" the shift knob left. Once the knob moves left, keep some pressure on the knob to keep it left then move it upwards into reverse. It'll take several tries to get the right pressure to do this. "Slapping" or moving it quickly usually works better than slowly and using a lot of force. My 2 cents.Over time once the metal fittings wear in a little this becomes easier.
Another tip here is to take out the ball joint of the shifter, attach the ball joint to a drill and work the ball joint in a bit. This will relax the ball joint and allow it to move easier. Once this is done, it will go into reverse a little easier.
Mine was extremely difficult to get into reverse after I re-installed it like the 3rd time. I ended up adjusting the cable linkage and it is much better now.
