Finally, got around to dyno tuning the car. The tuner first took the 9 data points of the Pro-M MAF and generated 30 data points. Plugged them into the Diable chip along with other parameters (injector size, etc). Did a couple easy pulls on the dyno to check A/F ratios. Running lean at higher rpm. Tweaked accordingly. Finally did a hard pull at WOT and the Lokar ss braided throttle cable bound in such a way as to not release!! Had to quickly turn off the ignition. No apparent harm done to the motor. Managed a couple more pulls, but the throttle cable was acting up. Could see it in some of the dyno profiles - not always giving full throttle when the pedal was floored. The last pull also showed some wobbling above 5,500 rpm. Wondering if valves were beginning to float? Thought I had adequate valve springs, but did not take into consideration blown application. Big valves have large surface area and there is 8 psi of pressure per square inch on the valve surface working against the valve spring. Intend to replace the Lokar with a polypropylene unit and go back for another dyno pull. Also, I now notice a hesitation from 1,800 to 2,000 rpm when driving. It only occurs at that narrow rpm range and in any gear (running a 5 speed). Your thoughts on the current tune and what to consider when I go back.
Jerry.
The 'wobble' could be the valve springs or may be the plugs. What plug and gap are you running? I have exactly the same top end 'wobble' on mine and I've convinced myself it's the springs after trying a lot of stuff on the ignition side. Eventually I will go with a custom cam and change the springs at the same time for now I just don't rev it out beyond 5500 rpm.
The A/F ratio looks pretty good, what max timing did you wind up with?
Ain't the Kenne Bell torque curve wonderful? Have him make a pull from under 2000rpm you should find that the torque is still just about as high at 2000 rpm as it is at 2500rpm.
Mike,
Was still running with 180 degree thermostat and cool plugs (Autolite 3923 gapped to 0.030”) during the dyno runs. This was my initial configuration to help prevent pre-ignition till I could get a dyno tune. Now that I've gotten a dyno tune, would you recommend changing the plugs to something different? If so, what plug and gap?
I suspect valve float in my case, too. Not too worried as I can shift above 5k rpm and still keep the motor in good power range for the next gear.
Not sure what total advance was. I have the dyno run files and the chip configuration file (.frg). Can view the dyno run files with WinPEP 7 software. Would that be in the one of those files?
jerry
Update - the hesitation from 1,800 to 2,000 rpm turned out to be a dead spot on the throttle position sensor (TPS). Replaced it with a new one, set TPS voltage to 0.96 vdc at idle and all is well.
Did you order a plain black lokar cable yet?
Yes. Ordered a 36" and 48" from Summit early Satruday. Will use the one that fits best and return the other.
