I am using mikespms brackets to return my retractors to the correct Corvette angles but did not record which ratchet blocks (removed as per FFR manual) go in which retractors. The rear retractors have one yellow and one black lever, the front one purple and one brown. Can anyone tell me the correct locations?
Discussion Starter · #2 ·
Trial an error shows that the belts will only pull out with purple and black on the pass side when the retractors are at the correct angles so I assume that is the solution..
Can our seatbelt specialist comment on the purpose of these balls which FFR had us remove? The plastic dogs which engage a nylon gear with very small teeth don't look capable of restraining even a small cat.
Thanks, I have read the explanations by Burnett and reworked my retractors as per his advice. I am just curious as to how these tiny plastic pieces play a part in locking up the belts under heavy forces.
