1 - 2 of 2 Posts
I was under the car today to adjust my clutch. Turns out it was a good thing I checked when i did. My cable has snaped 3 of the cable threads at the adjustment rod at the bell housing. It has been so long since it was put in, I forget what cable to replace it with. I have a late Mk II Roadster with the nylon pedal gear, an adjuster in the firewall and at the bell housing end of the cable it has a threaded rod for adjusting. I believe it is the same one as Finish Line sells, but not sure. Does anyone know what years of Mustang the proper cable is? Any help would be much appreciated.
Mikey
My thought is it is stock replacement mustang cable that is adjustable at the bottom. We always get rid of the nylon in the pedal box but if yours has you are kind of stuck with it. Look on Breeze and I think you will find what you need, HTH, Richard.
1 - 2 of 2 Posts
