This may have been covered already but there are so many shock threads that I couldn't find one dealing with this issue.
I have the bad springs and I will be replacing them. My dilema is what to do about the shocks. I've run them for 3,000 miles with the bad springs and, as far as I know, they are damaged and due to fail. I realize the smart thing is to replace them. What have others been doing?
Discussion Starter · #2 ·
I forgot to mention that I have wear on the adjuster barrels where the springs have been rubbing. Also, the springs are not square on the ends.
If you ran the shocks with the bad springs, Factory Five is taking the shocks back and will send you new ones.
Call them Monday.
Mojo:
When you call FFR, they will give you the proper instructions about your shock and springs.
