Hey guys I need some advise.
1. When installing the rear main bearing do I need sealant (RTV) under the rear main bearing cap. If so what kind, where does it go and is there a specific set up time for the gasket sealer? Pics would be great showing where to put the sealer if needed.
2. Should I install the one piece rear main seal while the rear main cap is off which seems really easy or wait until the rear main cap is on and then press it in. I am really leaning toward installing while the cap is off.
3. I have been using ARP assembly lube on the main bearing cap bolts. Is this correct?
Thanks, Eric
Thanks, Eric
