Over the winter I changed the rear drum brakes on my car to disks.
I used the following parts:
‘93 cobra brackets from LMR
‘93 cobra master cylinder
‘93 cobra/t-bird calipers and rotors
Ford Motorsports proportioning valve
Wagner pads
I did not change the pedal or booster which are stock foxbody parts.
I finally got to test drive her last night and my initial thoughts are that it requires more pedal effort than with the drums.
The proportioning valve is set at full pressure. If I really stomp on it I can lock up all 4 wheels, slightly less pressure will lock up the fronts.
I feel like with the drums I could lock up the front wheels with less pedal effort than it takes now, but it feels like I have better control for threshold braking than before the change.
The back brakes are probably not fully bedded in and will likely improve with more driving.
Wagner pads
