I have done a rear disc conversion. Found the correct spacers for the rotors with help from the forum. Moser direct fit axles. I'm having a problem where the 10.5 rotors wont clear the caliper brackets. It appears that i need to find 10 1/4 rotors. I pretty sure the calipers are off a 94 GT 4 lug set up. They are Varga calipers. I searched the brake FAQ section but did not locate any info. Has some one ran into this before?
I can't help but, check with Richard Oben at North Racecars.
Slacker Extraordinaire
I didn't think 94+ mustangs came in 4 lug. Are you sure you have the correct rotors? The GT should be 10.5" and the Cobra 11.65". What is the axle to caliper bracket from?
If they are 4-lug, they may be from a 87 or 88 Turbocoupe. As Doug said, Richard Oben is the guy to ask.
I will check with him thanks
