I recently bought a 5 lug rear disc brake conversion kit from Discbrakesrus.com. The kit uses 1995 Cobra claipers and vented rotors along with Richard Oben's rear brackets. After installing the brackets, calipers and rotors, I noticed that both the rotors rubbed on the inside of the the caliper bracket. I was wondering if anyone has had a similar experience with this modification?
It is a 1990 Mustang axle with 1990 and 1991 Ford Ranger driver side axles. All the bolts are tight, the C clips and pin is installed in the differential and the brackets are flush against the axle housing.
I emailed Richard Oben about it and his solution was to grind off what was rubbing and his installation instructions indicate that the rotor might need to be turned to fit. Neither of these seem like a good solution to me. Diskbrakesrus is going to send me another set of brackets to see if they fit better.
A few words of caution to those considering a 5 lug rear disc conversion:
1) Not all Aerostar passenger side axles from '86-'97 Aerostar will work. Some do not have a C lip on the end and have a pressed on bearing.
2) The Cobra rotor will not center on the axle as it was orginally designed. You will have to center it on the lugs with O-rings or machine a spacer.
3) You can't use regular SN95 caliper brackets, because they will not clear the wider vented rotor.
4) You can't use regular SN95 brake pads because they are too thick and will not clear the rotor.
Donny
Donny
