I'm installing the rear axle ('90 Mustang donor). The assembly manual shows what appears to be an older variant of the upper control arm mounts... no mention of the three holes I have to choose from. Any advice on which hole to start with? Also, I'm curious about the substantial chunk of cast iron bolted on below the pinion, a vibration damper I presume. Keep it or toss it? Thanks
3522K
3522K
