Been working on a full suspension re-vamp on my MKII. Still working on final design, but the idea is to move the shock assembly rearward and back, so the larger diameter QA-1 package can fit inside the UCA, and provide room for additional caster and camber. The as-built location would not, and the UCA would hit the spring. New set-up is very solid, provides excellent strength, 3/16" steel bracket directly attached to the UCA mounting point.
An additional interesting result, is now the shock assembly axis directly matches the ball joint axis, so both move in the same direction.
Softening springs in front from 700 to 500, but moving the VPM sway bar mounts to full firm. In addition, with the 700 springs, the shocks had to be run almost at nothing to have any affect. With the 500's, hoping now I can use them to tune the ride.
Rear springs being softened to 300 from 450.
With my back becoming more of an issue, and can spasm with the wrong move, time to make the car softer, so I would not cringe at every bump. But still want to keep it track-able. Hoping this concept can provide that.
Interested to hear your comments, and if anyone has done this, how it worked.
