Does anyone know if the IRS from the 03-04 Cobra Mustang will work with the Factory 5 IRS? I have a Viper six speed in my donor Mustang and I would like to use the IRS in my kit to keep the drive shaft movement to a minimum but I need an IRS that will stand up to the 490 hp that my motor has.
You can use the pumpkin and cv joints with the FFR supplied axles, but none of the frame, or other hardware is usable - except the brake hardware. You will still need the knuckles (outer spindles) from a t-bird, as the Cobra ones are the wrong design.
You guys rule. Great pictures Sergio. What do you think of the availability of these rear ends? eBay has one for $1800 with 27,000 miles on it.
I was looking on the order page and noticed that Factory 5 has complete kits- and you can order an IRS from them. Has anyone tried this?
Sergio:
Keep me in mind too,I'm looking for one also.
Where did you send your axles to have them made shorter for our F5 application?
Paul M
