Re: Hot Rod Body Buck
Hi All...found a bit of info on the site for building a wood-body-buck for a Roadster but didn't find one for a 33 HR...is there one posted anywhere and am I just not looking in the right place (would not be a surprise) or do I just modify this one posted for the Rpadster so it will fit the HR?
http://www.ffcars.com/forums/106-getting-started/168896-how-build-body-buck.html
...thanks in adnvance for any suggetsions! ([email protected])
Dan Melnik
Beaumont, CA
Very few builders use one. Mine sits on the ground outside the house now. I planned on doing the body work with the body on the chassis. The painter who will finish and/or fix my bodywork has his own stands and hangers.
I've seen some pictures of stands used to support the body parts above the chassis for storage. That looked handy if you have limited space. If you want to support the body for storage by supporting the body from the inside, the underside of the dash and aft body are nearly flat. It should be easy. If you want to support it for bodywork I would follow the lead of kgb911 or arrowhead, check out their threads.
Mine below. Measure your trailer (if you have one) and built it wide enough to roll over your trailer, then you can drop the body on/off trailer and chassis unassisted.
Rachet tie downs can be used to lower/raise the body carefully 6 or 8 inches at a time. The brace in the middle fits down into the passenger compartment so can lift the body all the way up high enough to clear the chassis but isn't much taller.
Plant Motor vehicle Wood Tree Grass
Plant Automotive tire Motor vehicle Wood Wheel
Plant Sky Shade Wood Tree
