1 - 15 of 15 Posts
I have some parts that I wont be using, so up for grabs they go. :)
All of the following is name your price.... (The distributor, and Regulator are gone.)
*FFR uncoated Mk4 side pipes, never ran, comes with hardware
*Motorcraft Alternator
*FFR Radiator hose kit
*FFR Serpentine belt
*FFR Hood Pin Kit
*Holley blue fuel pump (used, and worked great when came off car)
*Fuel pump block off plates, chrome, new
*Mustang gas pedal
*Mustang fuel tank, plastic shield, and straps, no pump/pickup (Local only please)
*FFR Fuel/brake lines
2007 Calendar Cover Car
Is the Ford mustand factory distributor/ with MSD cap for a carb engine (appears so...?). What year, and does it have a steel gear?
Also:
-What size / length is the fuel line?
-What pickup were you using in the gas tank? May be interested if it was for carb.
Thanks!
Also:
Thanks!
The distributor is a motorcraft, and came out of a 90 mustang, and has what looks like to me to be a steel gear.
The lines are (2) 5/16x60, (2) 1/4x60, (1) 3/16x20
The tank does not have the pick up with it, I used it in my tank, sorry.
1 - 15 of 15 Posts
