The 12 point bolt that hold the drive shaft on; what size socket? Thanks Walt
12 MM
Stan
master craftsman
12mm ,12point not 6point.....get it at sears, you'll also need a 7/16 , 12 point for the steering rack removal..........Steven
I'm on it thanks! Walt
Mumblerone
If locktite was used a little heat helps to free up the threads it took 1/2" breaker bar and 3/8" to 1/2" reducer to break mine loose,a long screw driver in the u-joint to brace aginst the tunnel wall helps
Ernie
