I'm in the process of fitting my pedals to my MKIII. I'm using an 87-93 pedal assy and will use a cable actuated clutch set-up.
Questions:
How much pedal travel is required or recommended for proper operation?
Are clutch quadrants different dimensionally for different applications? I have a BBK quadrant that came with the pedals and it appears larger than others I've seen.
Do the cables stretch alot? And will the pedal travel need to change ( or does it change) when the cable stretches?
Will I be able to take up slack as the cable ages with a cable adjuster?
Questions:
