1 - 3 of 3 Posts
Zipper-suited sun god and
I am using a non-TFI coil for my kit car (efi 347 w/ A3M PCM), the MSD high-vibration unit. My plan was to cut the TFI connector off and wire the two wires directly to the coil. Do I need a resistor in-line for this setup? Is there anything that will prevent this from working properly?
mk 1.5 original
Hi Dave,
I seem to remember there being a problem switching coil types like that.If there is a resistor in one it is to limit the current flow and protect the ignition module.
I would recommend using the correct coil for your ignition system MSD likely does make one. Check the MSD web site or a summit Catalog.
The correct coil probably costs less than getting towed home.
Chris
1 - 3 of 3 Posts
