Shade Tree Mechanic
Getting ready to place an order for some stuff with Mike Everson and was wanting to know what you all think about the Molex connectors? I want my dash to be completely removable. Are these the best way to do that?
they work fine,,,I used the larger .093 pins for the larger guage wire,,,get the tool to remove the pins ,,you'll need it,,get a seperate connector if you're using an aftermarket turnsignal setup,,,,,
Shade Tree Mechanic
Molex? Molex? Molex?
Thanks.
Shade Tree Mechanic
Bobby, I ordered the ones from Mike Everson. Two 12 pins....I think that should be enough for my whole dash, provided I can daisy chain some of the grounding, lighting and low amp feeds for the guages.
Bobby......a zillion???? :D
I used them for the dash area and weatherpack for exterior. They work well.
c
I have 3 to connect the dash.
Use them and be sure to get the larger pins. The crimp tool is nice to have also. I then soldered the connector to the wire.
