Does the bender require heating the metal prior to applying the bolt pressure?
I have a guy who can make one for around $50 but he thought that heat would be required for such a device (pictured in separate thread) to work with tempered pedal metal.
No heat required...
No heat required, and my pedal was not tempered, as I cut right through it with a hack saw with no problems. Pete
If you can remove the pedals from the pedal box, simply put them in a vice and use a large monkey wrench for leverage and bend. Took me about 20 seconds to bend both the clutch and brake pedals.
Discussion Starter #5
Thanks all. My pedals are in the car so I'll have the tool made and send it out to all when I am done.
I'm in Texas....anyone know where the pedal bender for this region is? And anyone know of a post/pic where the pedals are bent correctly (to work from...I am just preparing a box...don't have a kit yet).
Thanks!
