I want to pull the steering wheel. I'm afraid to force anything. In my opinion it should come off easy.
Anyone else have a problem?
This is the equipment I'm using. As far as I can tell the middle black screw sits on the shaft and is not interfering with the hub. It feels like it though.
Jason
Well Used Member
That puller should do it. Try putting the center Allen bolt back in, leaving it a few turns out from tight, then run you puller down on the bolt (rather than on the shaft). Use 3 bolts in the puller yoke. Once the steering wheel hub loosens on the shaft a fraction of an inch, take the puller off and center bolt out and it should slide off easily from there. It's that first 1/16 to 1/8 inch that's tough.
Also, when I put mine back together, I don't go crazy tightening that center bolt. I go just enough to make it snug.
(Oh darn. I said I wasn't going to post in this forum anymore, and yet here I am.)
Discussion Starter #3
Thank you for posting I appreciate it
I drilled my hub for a puller years ago, and I have used the puller many times. I now use a bit of anti sieve on the tapers of the shaft when I re-install the wheel. The hub is not as hard to get off, and it seats on the tapers just fine.
Discussion Starter #5
Awesome I will try it
I squirt some penetrating oil in there and then pull. I sit like I am driving and alternate pulling on the left then the right. Eventually it comes loose but be ready so it doesn't slam into your teeth.
I think a dab of anti-seize is smart. I had my hub on and off the shaft so may times during the build I managed to deform the tapered fit in the aluminum hub and it never fit very well afterwards. I replaced it with a new hub and have been careful ever since. Boat737's tips on removal and replacement are bang on.
Sean
Discussion Starter #8
I did pull it no problem I needed three points of contact. That was key rookie mistake and I knew that from pulling the engine apart too.
The bezel did not fit so the whole thing was a waste.
Thank you all
Jason
