1 - 3 of 3 Posts
It's time to order parts, since the MKIII isn't set up for the modern donor e-brake handle... :mad:
I visited Jeg's and came up with these two parts:
http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=4217&prmenbr=361
http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=4212&prmenbr=361
Does the handle fit the FFR factory mount on the passenger side? I'm doing Street Performer seats with the Breeze brackets, but I don't want the time and trouble of the trans mount modification if I can avoid it.
Also, do I need the Lokar cables, or can I use the cables that I presume are in the kit?
Thanks for the tips -- would like to order today or tomorrow.
Cheers, John
Aaron, unfortunately, that's not an option. The bracket attached to the frame isn't much longer than the two holes drilled. The brake handle mount holes are about an inch longer than what FF5 drilled. I looked for mounting options on John's car. He's got two. He either needs to get a new handle that matches FF5's holes or have a bracket extension welded to the frame and use this handle.
1 - 3 of 3 Posts
