I picked up a power steering pump for my 302. I've found that the steering column interferes with the pump. What have others done?
Skip Fergus
ford sells an AC eliminator kit that included a bracket that moves the pump to where the idler was. its about $50 and works well.
flush the pump well as they dont like dirt. that said i got a free pump from someone and used it for 3 years- if it leaks around the housing, you can replace the big o ring there- 50 cents.
james
There is a aluminum one that can be made, try a search, if not I have the template for it that another forum member gave me.
Check on the vendor forum under the free classified tab up top. There are a couple options available.
