I have had all the systems, now with EPAS.
Started off with the regular Ford PS System and 5.0 front motor dress, street Fox Mustang alignment settings.
The Ford systems could not handle any revs, everything blew up constantly. I then used the GM pump, brackets and stuff from Jones, varied pulley sizes, worked on alignment settings, and used the slower ratio rack, so the car was not as nervous. Admittedly after alot of trying things and laying back the caster, it worked well, I was happy.
New Motor with electric water pump changed the front motor dress completely, so I decided to try the EPAS from a Saturn View. Big project, and lots of experimentation, but I'm happy with it. I can vary the amount of assist, so both parking and putting around is easy with more assist, and on the track, I barely have any. Again with a manual slower rack. Also alot of experimenting with alignment settings, but it's quite good now. Only real negative of the EPAS is you do loose some road feel to the steering wheel due to the EPAS unit.
Happy to provide any more info if wanted.
