1 - 2 of 2 Posts
I need help! I ordered the march pulley set for the 460 with their brackets for the alternator and power steering. But the power steering brackets will not work with a manual fuel pump! (they should have told me this when I ordered.) I think I can use the march upper bracket and fabricate a lower one but before I go through with it I thought I would pose the question. Any suggestions?
Boy does that sound familiar. I ordered the same conversion kit and ended up sending it back. I deidn't have any problem with fabricating a bracket. However the problem is that you just can't seem to fit the power steering pump over there between the streering shaft pillow block and the mechanical fuel pump.
The way to complete what you are trying to do is convert to an electric pump fuel system, and fabricate a new pillow block for the steering rack.
Good luck.
1 - 2 of 2 Posts
