First start over the weekend and the new engine is running pretty good. But tonight I was trying to bleed the power steering rack when the steering wheel suddenly started jerking back and forth violently. I couldn't even hold on to it and had to shut the engine down. It does it both with the front end jacked up and on the ground. If I don't touch the steering wheel its fine but as soon as I touch it.....well, it jerked so hard to one side it pinched my braided stainless brake line. Could it just be a bad rack from AZ? The front ball joints are not tightened down yet as I still need to cut some off of the tie rod ends. Any help would be appreciated.
Todd
Pro FFR Builder and Moderator
Your lines are hooked up backwards on the rack
If you are tracking the car a cooler will be helpful. You would need more than a finned pan.
