1 - 2 of 2 Posts
I'm using std power brake booster and '94 Master cylinder. Do I need a combination valve? I recall a suggestion that a proportioning valve may not even be necessary. Using Cobra R disc brakes on all four corners. Also missing rubber boot on booster - Can you buy those separatly?
Just my opinion but the the divider and proportioning valves are both good to have. The first will help if you lose a line, and the big Cobra brakes in the rear may be a bit much for the lightness of the FFR.
I kept both in mine. Not saying you have to, but why not?
1 - 2 of 2 Posts
