1 - 3 of 3 Posts
what do i need to do, rather to buy in order to make 99 mustang brakes in the front and rear disks work. im using a 94 mustang cobra master cylinder. what kind on peices to i need and do i need a proportioning valve. im compleatly lost need help
Discussion Starter · #2 ·
or what do i need to do to the petal box to make my set up work with manual brakes
GO power definitely... You will need a fox booster I imagine and the master you have will be fine. You will need to mount the steering bearing on the inside of the footbox instead of the outside so it clears the booster. You will also need to remove the 3/4" tube just below the master cylinder location and replace it just below and a hair to the outside. This can be done by welding a new tube to it or Whitbys has a bolt-in kit that works well if you dont have access to a welder. You may need to pie-cut your brake pedal and have it welded in order to get it to the same level as your clutch pedal. Hope this helps!
1 - 3 of 3 Posts
