stainless? compound 302
Dude be careful! I used 302 on my pipes and I was looking at them yeasturday. I left some in the crakes of what would the j pipes and I damaged the finish I think. If not it discolored with heat. Just make sure you get it all off. The easy surface are perfect.
Musical instrument Wood Reed instrument Wind instrument Cylinder
Hi. What is everyone using to clean and polish ss side pipes on the roadster? Thanks.
I use Flitz polish, use terry cloth rag clean your pipes then you leave the polish on them and then mix up some dawn in warm water and wash them. It gets all the polish out from between the pipes and gets rid of the gold cast.
I had some really bad pitting and blue/copper discoloration. I used the compound 302 and to some degree it worked.
I went ahead and took the pipes off and bought a stainless polishing kit from caswell polishing. I grabbed an grinder/buffer adapter and went at it with black/green and then white compound.
