Body's going out to paint soon.Carpet is going in.
What is the best thing to get those gaps in and around the foot boxes filled and forgotten ?
Sten
I found some epoxy "putty" at a marine store that was perfect for a number of holes. You just cut a length of it, knead it in your hands and putty-up the holes. It's gray, like aluminum and cures rock-hard. They say it can even be drilled and tapped. Also, spray can expanding insulation foam can be useful. I had some special dark gray stuff left over from a water feature project that could be sprayed in and then trimmed off with a knife to a neat surface. Some of my holes I ended up cutting aluminum pieces and epoxying or riveting them down. Small holes respond well to silicone rubber from a tube. Last but not least, the Second Skin insulation with it's gooey butyl backing/adhesive pretty much sealed up everything else. In fact, I think she'd probably hold water now. Hope this helps.
I used a silver/gray silicon adhesive for the larger gaps between panels, and once it was dry, I covered every seam in the cockpit with aluminum HVAC tape. Then heat insulation, then carpet. Solid as a rock.
Where did you get the aluminum HVAC tape?
Bruce,
I have some of the aluminum HVAC tape. I think it would stick to a pool of oil....great stuff. It's actually thin aluminum with a pressure sensitive adhesive. I got mine at the local Home Depot. Most plumbing supply houses should carry it also.
c
65 FANGS
try lowe's for the aluminum tape. there are 2 kinds - on that is listed (has writing on it) for using on duct board, metal duct work, etc. about 2 1/2" wide, about 15.00 a roll. then there is a unlisted kind (no writing), about 1 1/2" wide, about 8.00 a roll. good stuff, will stick to about anything!
bob
Yep, got it at Lowes. Oddly enough, they didn't keep it in the HVAC aisles, but rather over by the paint with all the other tape.
