I am having a lot of trouble getting proper ride height adjustment in the rear with my pin drive width IRS setup and Levy's Konis. I have a ton of preload cranked into the spring just to get it where it is in this picture:
At full droop, the wheel barely hangs down as in these pictures:
I already have the long ends on the shocks that Gordon provides. The shocks I have measure 15 1/2" (eye to eye) at full extension (including the longer end). When I go from higher to lower levels of pavement you can feel the wheel "drop" and bottom out at the shock extension length. Something is not right with this and I am wondering if others are experiencing the same. Gordon has suggested redrilling the upper shock mount at a lower point but there is no room for that. The pickup point needs to be relocated which I'm not excited about doing. The shock seems like it needs to be another 1 1/2 - 2" longer. Any ideas from others with PIN DRIVE width setups?
