Status
Not open for further replies.
There appears to be two different size pillow blocks in the kit...Which one goes where???and does it matter which way they face???
Thank you
[ September 06, 2002, 10:10 AM: Message edited by: Badcaiman ]
the small one is for the upper shaft assemly, the other is for the lower shaft in the engine compartment.
· Banned
The assembly manual indicates that the front pillow block should have the locking collar on the front side of the bearing. I couldn't find where the manual says which direction to place the collar on the rear pillow block. I placed it on the back side toward the steering wheel.
>>Think about it this way....You want the >>steering wheel to collapse in but not pull it >>out.
Which means that both bearing collars must be in front of their respective pillow block??? I want to be certain that I understand.
I agree - the manual is very clear on the lower pillow block, and completely silent on the upper.
Chip
· Senior Charter Member
BRG
That's the way I did it. Both bearing locks on the front of the car side of the pillow block Mike and I used the same logic on this one.
clear now ... thanks
Chip
Status
