Before you install your lights, I recommend you add a drop of solder to the wire end where it connects to the light. They come just crimped and the connection isn't too good. It will likely get loose or corrode or both. Do the same with the license plate connection by using the cut off ends as mentioned above by.
I found a connector that fits snug over the brass ends at the local NAPA store.
This way no cutting :D
Gord FFR 2359
