1 - 2 of 2 Posts
Any pictures of rear brake lines with the '99+ Mustang flex hoses. I'd like to see how the bracket on the flex hose is attached to the frame. Also, where did you route the lines. I noticed on the hose for the right side (pass.) has two ports. Apparently, one is for a hard line that runs to/from the left (driver) brake caliper and the other port is for the hard line to run to the m/c.
Thanks in advance for your help.
Troy
Discussion Starter #2
I forgot to add that I'm running the solid axle.
1 - 2 of 2 Posts
