1 - 3 of 3 Posts
I tried uploading a picture this morning and it says I'm out of room. I tried to delete one to make some space and it says invalid file name. What's the secret here? Is there some trick to the picture management thing? Thanks
Frank
Hi Frank,
The system won't let you delete files with spaces in them. What you have to do first is select the file and then edit the name in the text box so it has no spaces. Then select the "Rename" button. Then you can select it again and delete it.
Hope this helps, Rod
1 - 3 of 3 Posts
