Anyone have any good pics of the AC unit hard lines, the mounting of the accumulator, and routing of the condensor lines? Maybe Aluminum panels in the radiator and passenger footbox area? I would really appreciate it. I'm flying blind here! :confused1:
back of manual shows this installation of a/c unit.
put a/c unit in before any of the aluminum panels from the passenger foot box. install aluminum panels for the underside rad area and then install both rads. follow the instructions and you will be fine.
I know what you mean, the picture shows mine laying down facing bottom of pic. I turned it and connected it.
I am working on the car tomorrow, so I will take a picture of that area for you.
Can I bring the hardline to the accumulator over the 3/4" bar? Or am I going to run into issues later?
Also the o-rings into the accumulator don't seem to compress any. Ideas?
Thanks!!
That o-ring needs to be replaced with a thicker one. NAPA has them. You will likely need to bend the hard line also, to get it routed where you need to go. It's soft aluminum, so I usually just form it carefully by hand.
