1 - 3 of 3 Posts
I have a set of beautiful PSE wheels. I popped a flat on the freeway Friday and unfortunately I trashed the rim.
I need 4 lug. The rear wheel is 10 inches wide and I don't know the other measurements...only that I told Phil I had an 8.8 rear end going on a mk3.1 and I wanted 295 rear tires. He made what fit.
Sorry to hear about that and you might get lucky finding a replacement wheel. Another option, check out getting it repaired. Unless it is really bad a good shop can fix most damage. Talk to the service guys at a higher end car dealer like BMW, they know the good places in the area.
David
Glenn, the PSE rims are spun from sheet material and are not cast (like the centers). As a result the rim is not brittle and should be a relatively straightforward fix for a good rim repair shop.
1 - 3 of 3 Posts
