Which PCV valve do I buy for the Ford Racing carb-style valve covers? It's a push-in style, but the guys at the Ford dealership just stared at me blankly when I asked.
1st RFM/FFR Legacy Winner
Do you already have a hole for it? I didn't so I found one at Advance that had a 90 deg angle. Although it was for a Cheby 350, I chose it because it was about 3/4" in diameter and came with a 1" grommet. I drilled a hole in the driver's side valve cover near the firewall to install it and also built and aluminum baffle plate which I screwed and JB welded into the inside of the valve cover so it wouldn't suck oil-just vapors.
Discussion Starter #3
The valve covers came with the holes.
I just measured the hole, and went to autozone and looked at the "wall o' pcvs" until I found one that looked about right.
