I figured I'd trial fit the pass side roll bar before putting on the rear trunk sidewall panel. The bolts that secure the rear roll bar mount will not allow the sidewall to sit flush with the frame rail. I figure my options are to either get out the hammer and dimple the side panel or drill holes in it. For those with pass roll bars what did you do? As always picture are appreciated (not that I can't read, I'm just more of a visual learner)
Kevin
Kevin,
I drilled the alum sidewall panel and bolted through it and the steel mounting plate and things lined up nicely for me. HTH.
Kevin,
When I drilled the bottom bolt in the roll bars I went on thru the aluminium and then enlarged the hole and put plastic plugs in I got from Home Depot
Ernie
Thanks guys. I'll go with the holes and plugs.
