1 - 2 of 2 Posts
Eng. Ed, What are the deminsions of the strips and space between the strips? Thanks for your past help. Can the front hood hinge be added after the car is finished?
Lugnut,
The stripe dimensions are found here:
http://www.ffcars.com/FAQ/stripes.html
You can install the hood after the painting.
Install a few pieces of scrap hood weather stripping to assure proper assembly location.
Then measure where the stripes will be located.
This way after its painted, the stripes will line up correctly.
I'd mount the hood hinge with removable screws first to align everything prior to painting.
That is how I did mine. Just use care when installing to avoid scratching paint afterwards.
Ed
FFR1997K
1 - 2 of 2 Posts
