Nick
Looking for a strong paint stripper that will remove several coats of paint and bondo from a 1947 truck project, a stripper that works quickly that won't melt my shop in the process. Any ideas? How about airplane paint stripper? Thanks
keith in your neighborhood knows a guy in sherwood that uses walnut shells (media blasting) takes off everything but doesn't hurt metal.
I'll as Doc my car restorer friend for his recommendation as well.
Aircraft remover, you can get it an autoz. wear an old long sleave shirt and some rubber gloves. it will take off layers of paint and soften bondo
Aircraft remover, you can get it an autoz. wear an old long sleave shirt and some rubber gloves. it will take off layers of paint and soften bondo.
Report from Doc
Aircraft paint stripper: all the part stores sell a similar stripper.
Trick is cover the area with black trash bags after you apply it.
Any vinyl bag works and set it in the sun (what sun!), keeps it from loosing
the chemical.
I would just send it out to be dipped! No waste at your place, and
you start with clean stuff!
