I've got the one wire alternator from Mr. Alternator. Hooked up the 915/916 wires from the Painless harness, but unsure where the 914 white wire connects. Logic says it should go to the green wire on the alternator, but wanted to check here first.
Also have an MSD 6AL and the MSD coil. Using the MSD Ford adapter harness to connect everything. The 920 Pink wire from the Painless harness needs to connect to the coil as well, but I'm not sure where it goes.
920 pink goes to the small red on the MSD and provides switched power for the ignition system. The 914 white does not get used with the 1-wire.
Thanks Joe. Just splice it into the MSD adapter harness then?
Shep.. The white wire can be used with a switch to ground. Read the MSD directions under security.. hide the switch and turn it on when leaving the car and the MSD is disabled and will not allow car to start.. cheap anti-theft..
ok you can all stal my car now but ......
jd
